Paint peeling off posted by quadratique on June 23, 2013 at 09:20 PM
-What grit/pad did you prep with? -Did you wipe it clean with wax/grease remover followed by a tack cloth as your last step before priming? -What primer did you use? -Was it single stage or two part? -What thinner and what application method did you use? -What were the conditions during coating (temp,humidity)? -Was it a non sanding primer, or were you supposed to sand before basecoat? -How long did you wait before applying your basecoat?
